when project name different from directory name where the project resides in, sharing with integrity create a new directory with the project name. When executing checkout from Integrity all files are checked out in the new directory. Is there a way to use different project name and directory name?
Hi Thien,
Some screenshots may help convey what you're asking, as I'm not sure exactly, what issue you are describing. You may also want to open a Support case for this.
I suspect the behaviour you are seeing is probably by design, with the integration, but can you provide more info, to clarify?
