Member check-in
kkomarla
1-Newbie
Member check-in
How does Source Integrity indentify that a member has been modified and can be checked-in?
As per my understanding this happens when:
* the contents of the members have been updated/changed;
* the member file's modification date has been changed.
Please let me know if my understanding is correct?
I am trying to understand how the source integrity decides when to update a member’s revision with default policies in place.
1 ACCEPTED SOLUTION
KaelLizak
(To:kkomarla)
Hello Karthik,
The old system used heuristics including time-date stamps and file size.  It usually works.
As of Integrity 2009 SP4, this can be done with checksums (CRC), by using the instructions in this article.  To my knowledge, if this configured it always works.
Kael
Kind Regards,
Kael Lizak
Senior Technical Support Engineer
PTC Integrity Lifecycle Manager
2 REPLIES 2
KaelLizak
(To:kkomarla)
Hello Karthik,
Kael
Kind Regards,
Kael Lizak
Hi Kael,
I was under the impressin that with Integrity 10.5 too the check in happens under two conditions time-date stamps and file size with default policies in place.
I will look into the Checksum though.
Thanks and Regards,
Karthik Komarla
