Multiple bars for one value on the x-axis
ptc-5279365
1-Newbie
I would like to create a veritical bar chart that effectively has two queries.
For each "Build" I would like a veritcal bar to represent - "Found in Build" and another bar for "Fixed in Build".
I have tried lots of different options and have not been able to get this.
Is it possible? Thanks for your help, - Michelle
3 REPLIES 3
mrump
(To:ptc-5279365)
Hi Michelle,
IMHO using two querys in one chart is not possible by design.
If you are just interested in the "numbers", You could use a workaround by creating computed fields for your BUILD item type. THese computed fields can be query based and you can chart the values of the separate fields for your builds.
The only other option I see would be a custom chart created for a example via a report.
HTH
Matthias
KaelLizak
(To:ptc-5279365)
Hello Michelle,
Depending on the type of chart you are using, this might be possible. Could you let me know what kind of chart you are doing this with?
The method, if it is even possible, is not abundantly obvious, and I will need to check my notes from some time ago to see if I did it successfully, or tried it and found I could not do it. I will look into it more some time next week, if things calm down here.
Kael
Kind Regards,
Kael Lizak
Senior Technical Support Engineer
PTC Integrity Lifecycle Manager
MrKis
9-Granite
(To:KaelLizak)
Hello Kael,
Did you find anything in your notes?  Is it possible?
