Windchill PLM "Thingworx Navigate Apps" Tips & Techniques Session Recording
100% helpful (1/1)
Check out this video on Using Windchill "Thingworx Navigate Apps" from PTC Application Engineers
Presenters: Steve Ashley (Solution Consulting, Fellow), Ryan Butcher (Solution Consulting, Fellow).
Original Date Presented: August 16, 2023
To dive deeper into the subject, check out Thingworx Navigate Apps
Comments
WEBCAST Q&A
Question from Bill:  How does Document Structure show up in Windchill PLM?
Answer:  A document structure allows you to define parent-child relationships between documents.  These relationship are reflected in a hierarchical table in which each document uses the documents that appear below it.  You can use the document structure browser located under the Structure tab on a document information page to create, view and manage document structures.  It is a structure like a WTPart structure in Windchill and just uses documents.
WEBCAST Q&A
Question from Michael:  My mind is blown...We have been using Thingworx for almost a year, but we are not getting the full value that is being shown here.  Is this all available out of the box?
Answer:  Yes.  The Thingworx Navigate apps need to be installed separately, and then everything that you are seeing here is OOTB.
Version history
Last update:
‎Aug 25, 2023 11:57 AM
Updated by:
Contributors
