Check out this video on Using Windchill "Windchill Extensions" from PTC Application Engineers
Presenters: Ryan Butcher (Solution Consutlting, Fellow) and Donna Fedeli (Solution Consulting, Principal).
Original Date Presented: December 21, 2022
To dive deeper into the subject, check out Windchill Extensions Website
WEBCAST Q&A
Question from Jon: Has IHS corporate structure change affected the IHS extension?
Answer: For the Wincom app there are no changes to the extension. I'm making the assumption you are referring to IHS Markit now being a part of S&P Global.
WEBCAST Q&A
Question from Patrick: Can you set conditions for watermarking? For example, if the data is government purpose or unlimited rights the watermark should be removed.
Answer: You can set based on Security Labels.
It seems like spliting some functionalities to bundle of extension for extra license . Come on
