Would you share any related error in logs
2025-03-27 08:59:17,748 ERROR [ajp-nio-127.0.0.1-8011-exec-2] wt.pds.exception zeke.liu - Suppressing internal message (wt.pom.pomResource/0) wt.pom.PersistenceException: A persistence error occurred. System message follows: Nested exception is: wt.pom.DatastoreException: A SQL error has occurred. Database system message follows: Nested exception is: java.lang.ArrayIndexOutOfBoundsException at java.lang.System.arraycopy(Native Method) at wt.units.Unit.readVersion_6722550756304252532L(Unit.java:2081) at wt.units.Unit.readVersion(Unit.java:478) at wt.units.Unit.readExternal(Unit.java:456) at java.io.ObjectInputStream.readExternalData(ObjectInputStream.java:2118) at java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStream.java:2067) at java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1573) at java.io.ObjectInputStream.readObject(ObjectInputStream.java:431) at wt.units.FloatingPointWithUnits.readVersion4226946163825851459L(FloatingPointWithUnits.java:273) at wt.units.FloatingPointWithUnits.readVersion(FloatingPointWithUnits.java:93) at wt.units.FloatingPointWithUnits.readExternal(FloatingPointWithUnits.java:72) at java.io.ObjectInputStream.readExternalData(ObjectInputStream.java:2118) at java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStream.java:2067) at java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1573) at java.io.ObjectInputStream.readObject(ObjectInputStream.java:431) at wt.pds.AbstractLobHandler.getLobAsObject(AbstractLobHandler.java:396) at wt.pds.SQLDatabasePds.getLobAsObject(SQLDatabasePds.java:1602) at wt.pds.WTResultSet.getLobAsObject(WTResultSet.java:1075) at wt.pds.WTResultSet.getObject(WTResultSet.java:349) at com.ptc.core.lwc.server._LWCAttributeDefaultValue.readExternal(_LWCAttributeDefaultValue.java:222) at wt.pds.WTResultSet.readObject(WTResultSet.java:679) at wt.pds.PersistableItemBuilder.build(PersistableItemBuilder.java:559) at wt.pds.StandardACProcessor.processResults(StandardACProcessor.java:99) at wt.pds.SequentialResultBuilder.build(SequentialResultBuilder.java:432) at wt.pds.BasicResultCursor.next(BasicResultCursor.java:93) at wt.pds.SQLDatabasePds.query(SQLDatabasePds.java:837)
