I'm with Steve,
What is your Windchill configuration. (i.e.winchill version.) Was your schema properly updateded? Do you have Partslink also installed with a different database user?
Is the log specifically from the upgrademanager.log/xml?
Was there any successful load of data before this step. Can you repeat it? Rehost from production then reupgrade again.
Patrick
In Reply to joe bell:
Any successful 9.1-10.2 upgrades out there?
While running the UpgradeManager, the Load New Data task fails at the Type data loader for 10.0 step.
I can find nothing that addresses this specific error.
Caused by: wt.util.WTException: (wt.ixb.publicforhandlers.ixbResource/8) wt.ixb.publicforhandlers.LogHelper$IxbException: Problem in export/import process.
Nested exception is: (wt.ixb.handlers.netmarkets.NMIxResources/108) wt.util.WTException: Loader method com.ptc.core.lwc.server.TypeDefinitionLoader.endProcessTypeDefinition reported a failure
Has anyone had and solved this issue?
joe bell
GSIMS Administrator
GPS Sustainment Information Management System
719-572-2890
bellj@gpssims.com<
