you can have a look "NavigationCriteria" object and related methods:
Fetch Navigation Criteria:
NavigationCriteria navigationCriteria= NavigationCriteriaHelper.service
.getNavigationCriteria(filterName);
navigationCriteria.getConfigSpecs() and find the one with WTPartConfigSpec.
Cheers,
Xolomon
Hi @xolomon
Thank you for your replay.
I know the NavigationCriteriaHelper but I haven't found a way how to read actual user's settings from the Structure filter
I will check it tomorow. 😄
PetrH
Hi @xolomon
The NavigationCriteriaHelper.service can return saved filters. I can not find the actual settings which could be modified by user any time.
I can list all saved filters and get configSpecs for filter by name, but it is not what I need.
I would get actual settings that is read in a configure wizard. But I'm not able to locate where the filter specification is read and by what API.
PetrH
I just add a example
A custom table in custom tab should shows tree based on Structure filter, but I can not find a way how to get the settings of actual filter settings in the TreeDataHandler or TableBuilder.
as a workaround I use an own lifecycle filter but I would like to know to get the structure filter.
PetrH
