AWS / CLUSTER / HTTP error 504 "Windchill/servlet/javaRMIServlet?forward=5003"
schauvelin
When validating a Node in Vault configuration applet panel error "HTTP error 504 "https://CLUSTER_ALIAS/Windchill/servlet/javaRMIServlet?forward=5003"" is displayed after 10 minutes.
Customer is on AWS and configured a cluster node with Windchill 10.2 M030 CPS28 after a rehost.
JMX/RMI ports are opened on both node and telnet is working.
Error message below is displayed in NODE2 MethodServer.log  :
ERROR [RMI TCP Connection(2626)-XX.XX.XX.XX] wt.fv.FvMountValidator wcadmin - java.rmi.ConnectException: Connection refused to host: NODE1.ptcloud-internal.ptcmsprod.com; nested exception is:
java.net.ConnectException: Connection timed out
Nested exception is: java.rmi.ConnectException: Connection refused to host: NODE1.ptcloud-internal.ptcmsprod.com; nested exception is:
wt.util.WTException: java.rmi.ConnectException: Connection refused to host: NODE1.ptcloud-internal.ptcmsprod.com; nested exception is:
at sun.rmi.transport.tcp.TCPEndpoint.newSocket(TCPEndpoint.java:619)
at sun.rmi.transport.tcp.TCPChannel.createConnection(TCPChannel.java:216)
at sun.rmi.transport.tcp.TCPChannel.newConnection(TCPChannel.java:
Any specific config for AWS when doing cluster configuration?
Thanks in advance for your time on this topic.
Kind regards.
0 REPLIES 0
