Hi.
I need to hide "relatedPartsDocuments" and "relatedPartsCADDocuments" tables from info page of wtpart softtype (an only for this softtype).
How should i define UIComponentValidator not to brake standard behavior of these tables?
I know how i can get action name and softtype id in UIComponentValidator. The question is how not to affect standard display settings for other softtypes?
Thanks.
Should i extend RelatedItemsPartsValidator instead of DefaultUIComponentValidator ?
Hi Vasiliy,
Could you clarify how this is the correct answer for the rest of the community?
Thank you,
Jarrett
public class RelatedItemsTablesValidator extends RelatedItemsPartsValidator
public UIValidationResultSet performFullPreValidation(UIValidationKey cUIValidationKey,
UIValidationCriteria cUIValidationCriteria,
Locale cLocale) throws WTException
UIValidationResultSet resultSet;
if(my conditions)
resultSet = ..;
else
resultSet = super.performFullPreValidation(cUIValidationKey, cUIValidationCriteria, cLocale);
You have to use typebased builder to make it specific to SoftType
Hi
I know nothing about "typebased builder"
Alternatively you can use this condition to filter sub-type
if(( TypeIdentifierHelper.getType(localWTDocument).toString().equals("WCTYPE|wt.doc.WTDocument|
com.ITCINFOTECH.Agenda ")))//internal name of your subtype
Thanks And Regards,
Kaushik
