Eric,
If you click Options then Add Context next to "Context" you can select which location you want to search in. Then if you click Add then More and select Created By next to "Criteria" you can specify the creator of the assembly by clicking the magnifying glass next to the text box. To narrow down the search to Pro/E and other CAD documents you can select the CAD Document checkbox in type but this would bring up more than .asm objects. To get the search you are looking for you would have to keep the search term as '*.asm' or you could put that as the criteria for Name or Number.
After you add the Created By, Context, and *.asm term, you can click the "Save this search" link in the top right and it should be all set for you. Please see attached image for better clarification.
Hope this helps,
Todd Burkhart
ProductSpace Solutions, Inc.
You will need to search in Folder and later edit and save the query. See attached
Per PTC's site & CS22115
Has anyone here applied the M040 patch & can you confirm that the search in folder function is back?
