Amazon Corretto Open Java Development Kit (OpenJDK) Support in Windchill PDMLink 11.2.1.0
Amethyst
Amazon Corretto OpenJDK is supported for installing and running Windchill. Amazon Corretto OpenJDK is alternative to the Oracle Java SE.
You can choose from Oracle Java SE and Amazon Corretto Java as the JDK to run Windchill. Amazon Corretto Java 8 is supported for this release.
You can refer to the Windchill Software Matrix on PTC.com for details of the supported versions. Or TS Article CS318019.
Tags (1)
