Aphelion Web Tool
rstav
Aphelion Web Tool
Windchill Gurus,
I have been asked to setup a password policy for Windchill.
We are currently on Windchill 9.1 M060 and still using Aphelion. I know...I know I should be on Windchill DS.
The problem that I am experiencing is...logging into Aphelion as an administrator to setup the password policies. I have the Aphelion password written down from when we originally setup Windchill 8.0 and have not used it or changed it since.
When I bring up the Aphelion Web Tool and try to log in using the username and password it will not let me.
Am I missing something?
Rich
Richard Stavish
Pro/E System Administrator
[cid:image001.jpg@01CD8132.694C5310] [cid:image005.jpg@01CD8133.145EBA40] <">http://www.linkedin.com/company/sargent-aerospace-&-defense> [cid:image007.jpg@01CD8133.145EBA40] <">https://twitter.com/#!/SargentAero>
E-mail:
Office:
Fax:
Mobile:
RStavish@sargentaerospace.com
520-744-1000 x4570
520-744-7529
520-437-5811
8 REPLIES 8
For the user ID make sure you use "cn=Manager" not just "Manager".
Just a guess.
rstav
(To:rstav)
I tried that, still not able to access.
Richard Stavish
[cid:image001.jpg@01CD813B.BFDC45B0] [cid:image003.jpg@01CD813B.BFDC45B0] <">http://www.linkedin.com/company/sargent-aerospace-&-defense> [cid:image004.jpg@01CD813B.BFDC45B0] <">https://twitter.com/#!/SargentAero>
E-mail:
Office:
Fax:
Mobile:
520-744-1000 x4570
520-744-7529
520-437-5811
rhoffmann
(To:rstav)
You may be able to see the password for M060 to Aphelion in ie.properties in codebase\WEB-INF if the new encryption functionality has not been enabled.
rhoffmann
(To:rstav)
Sorry, was wrong on that. It's been a while since I had to search for the Aphelion password.
Is the password stored in the Aphelion install log files? I can't recall.
BenLoosli
(To:rstav)
It is in the summary of the install if you save it as the last step before selecting the Install button, at least on the 9.0m050 install I did yesterday it was.
Thank you,
Ben H. Loosli
USEC, INC.
imendiola
(To:rstav)
I will have to check my notes about this, because it has been a while since I worked with Aphelion, but I think that the user/password that must be used to log in to the Aphelion Web Tools page was not the LDAP Administrator (cn=Manager)... I think that it should be an Operative System user/password assigned to a specific group...
Iker Mendiola
Prambanan IT Services
http://www.prambanan-it.com
http://www.prambanan-it.comIker Mendiola - Prambanan IT Services
imendiola
(To:rstav)
Ok, I have found it:
After initial installation, you must satisfy the following requirements to log in to the Web interface:
• Must have a valid username and password defined on the host machine.
• Must be a member of the LDEadmin group (the group name is case-sensitive).
If you are not a member of the LDEadmin group, contact your administrator.
The user and group must be in the Operative System, not in Windchill or LDAP.
Iker Mendiola
