Applets are Failed to Load
vuchekar
Hello All,
On Monolithic Windchill Server 10.1M040, All Applets are failed to load.
Its shows a message in Pop up's as below,
The following error occurred during initialization: The operation: "getGlobalDomain" failed.
Nested exception is: wt.util.WTRemoteException: Unable to invoke remote method
Nested exception is: wt.util.WTRemoteException: Unable to locate method server
Nested exception is: wt.util.WTRemoteException: Unable to get server
Nested exception is: java.security.AccessControlException: access denied ("java.net.SocketPermission" "127.0.0.1:5002" "connect,resolve")
Please guide us to solve this.
Vivek
8 REPLIES 8
ngiacom
(To:vuchekar)
kkazi
(To:ngiacom)
Thanks!
This fixed my problem as well.
Nested exception is: java.security.AccessControlException: access denied ("java.net.SocketPermission" "connect,resolve"); nested exception is:
(wt.fc.fcResource/0) wt.util.WTException: The operation: "getObject" failed.
ChrisSpartz
(To:vuchekar)
What version of Java are you using on the client machine?
ngiacom
(To:ChrisSpartz)
Normally I use Java 1.7.25 but the issue there is with Java 8.
The article solved the issue for me.
Hello All,
Thanks for your suggestions and response.
This issue was fixed after editing java.policy file.
Vivek
jessh
(To:vuchekar)
One should not have to use a java.policy file to get applets to work.
A couple of thing here:
  1. One should be sure the server has the latest generic patches for Java client compatibility -- various recent changes in the Java applet security model have required patches to Windchill.
  2. Java 8 clients are not yet officially supported with any version of Windchill. They will be with 10.2 M030. Whether or not they are officially supported, the applet security model in Java 8 requires all RMI to be tunneled. Workarounds include fully signing an applet (impractical except for a couple of Windchill applets) or editing the java.policy file, but the general approach is simply to enable RMI tunneling, which is enabled out-of-the-box in 10.2 M030.
Is there any word yet on Java 8 support for builds of Windchill prior to 10.2 M030? Specifically 10.1 M040.
jessh
(To:jbailey)
I know of no official news at this time for previous releases.
