One of the engineers here is attempting to check in models - check in fails and he gets the following message:
A persistence error occurred. System message follows:
He is unable to find the system message to give a clue as to the failure... any thoughts?
Are the other users able to check in files? This sounds like a database issue. Do you see something in the method server logs? Error looks similar to a bug 10.2 M030 with delete workspace
I did find the persistence error occurred line
Looks like index is corrupted. After your DB backup try the below
SELECT
OBJECT_NAME,
OBJECT_TYPE
FROM ALL_OBJECTS
WHERE OBJECT_ID = 30101;
If is an index, try rebuilding it
ALTER "INDEX_NAME" INDEX REBUILD ONLINE;
Thank you
Binesh Kumar
Gordon,
Was the issue resolved after rebuilding the corrupted index?
Let us know if you're still seeing the issue with check-ins.
Hello Binesh
Even i am geetting the same erro , while deleting the Family table Instance in Windchill 11.0 m010
Hello Binesh,
Even i have been facing the same error while trying to delete the latest itteration from the PDM.(Windchill 11.0)
I am having a very similar problem. I have 3 items in my work space, that are not check out, have + sign next to them indicating that they have been modified and updated. I can not check them out nor can I delete them without getting "A persistence error occurred. System message follows:"
Most of what I read above is over my head.
The last time I received this error I had to check out the WTP's in the same Workspace and check the asm in. The WTP's got checked in at the same time.
Dear gchapman,
Did u resolve this issue?
I'm facing same error while trying to check out the files.
Can you please help out with the solution.
Thanks in advance.
Sumanth
Had this issue today. Same as all no real information as to the cause of the error. Was checking out a EPMdocument along with 24 WTparts that were associated. The workaround was to add the objects to a workspace. Then I checked out only the EPMdocument. Then I checked out all of the WTparts except the two that was causing the issue. Then I checked out the last 2 WTparts with no error.
