If you have an explicitly mapped attribute, and you populate that attribute in a drawing from within Windchill, should not this attribute populate in the mapped parameter of the CAD model once that CAD model is opened in a Creo session? Shouldn't the client-side workspace automatically synchronize the metadata? The example follows.
Attribute Name = My Box
Attribute internal Name = MyBox
Creo Field Mapped Name = CARTON
Creo Drawing Parameter = CARTON (designated)
Creo Model Parameter = CARTON (designated)
Operation
Perform Check Out and Edit Attributes on drawing in Windchill (MyBox = Standard)
Check In drawing
Open associated model (,prt) in Creo
Should not CARTON = Standard?
Not sure if you solved your problem.
I can suggest write parameter:0=parameter:D in the program of the drawing.
in your case CARTON:0=CARTON:D
Please tell me if it works for you or if you found another workaround.
This question was from 9 months ago...
No, making changes to the drawing's parameters, either in Creo or via the Windchill attributes, will NOT change the parent model's parameters. A drawing program (as shown above) WILL allow the drawing to automatically follow the model, but only when the drawing is opened in Creo. To the best of my knowledge, this only works one direction, from the model to the drawing.
Also, be very careful with the ":0" syntax. This will refer to the first model in session and may not be the drawing's parent model. If you're on a more recent build of Creo, the better syntax is ":MDL". This will automatically convert to the proper session ID for the parent model.
