I just put in this tech support call:
We are using the attribute "Project Charge Number" assigned to multiple types with the Discrete Set constraint. Users select a number and all work done is charged to it. This is for accounting purposes for hours worked by various groups / departments. We currently use the same set of charge numbers for two different types of Change Request and also two types of work request (we're using a sub type of Change Request as Work Request). The valid list of Project Charge Numbers updates frequently. We have to independently update the list for each type. Question: Is there some way to have a single list applied? It appears that the ideal solution would be to use a resource bundle, and to have the values displayed in a Discrete Set be the current values of the Resource Bundle. Is this possible? Has anyone done this? Any other suggestions?
Hi Swamy,
we also have the requirement to update the discrete value set of an IBA of one of our WTDocument subtypes regularly. This should happen in some kind of overnight batchjob without having to use the "Type and Attribute Manager" user interface.
I thought of using a loadfile but it seems not to be possible to edit an existing discrete value set this way. I also was not able to find any Java API or I*E Task functionality to achieve this.
Can you provide me with more details on your solution using the flat file with predefined values? I guess this way I would not have to update the discrete value set.
Your help would be very much appreciated.
Best regards
Paul
