Hi Everyone,
I am using the below steps to fledged the attributes in "My Task Tab" to find the who is created a promotion request. That user name get from Custom Table. I want same like this to get a some attributes from EPM/WT. For example i want the EPM Document object which i get into Promotion request that object state view in my task.
1. Go to Site > Utilities > Types and attributes - Create an Alias attribute in the Type "Work Item" named "Requester of the Promotion"
2. Add this mapping the the attribute and save: primaryBusinessObject^wt.maturity.PromotionNotice~creator.name
3. Go to the Tasks table and customize view Add the column "Requester of the Promotion" with the columns that are shown
Thanks in Advance,
Amir
Because, the primary object is not EPMDocument and you can not retype it to unsuitable object type.
You need to find a link between PromotionNotice and Promotables .
so, primaryBusinessObject^wt.maturity.PromotionNotice - PromotionTarget - EPM
you need to find correct mapping.
here is example how it works the to other direction
Create Alias Attribute with hyperlink to show the Promotion Request Number
PetrH
Thank you for the replied Mr. Petr, Thanks for the information.
Step:1 I create a Promotion Request for one EPM Document & it's already in "Released" state.
Step:2 Like a image 1 Promotion Object State is Released
Step:3 Image 2 State is Released that appeared in Promotion Object.
I want that attribute with value in My task. for example before promotion if it's inwork state mean inwork will appear in My Task Tab.
Warm Regards,
Amir
So you want to show in the task the source Life cycle state of the promotable object?
Do you know that each object can have different source life cycle state? but just one target state?
PetrH
Yes Mr. Petr, both are two different lifecycle state, primaryBusinessObject^wt.maturity.PromotionNotice~creator.name it's work i done same thing get the promotion request state into "My Task Tab" primaryBusinessObject^wt.maturity.PromotionRequest2~state.state
we can use the Alias Attribute to get this, i tried to mapping with primaryBusinessObject^wt.epm.EPMDocument~state.state this i didn't get this that why.
Amir
PetrH
