Export work flow with error
  • October 27, 2023
  • 2 replies
  • 1509 views
Export workflow with error
wt.workflow.definer.WfExportImportHandler.addWfRolesResetMap(WfExportImportHandler.java:850)
How to fix?
Best answer by Rocket_Max
Hi @YZ_10818805
Try to restart windchill and clear the cache...
Cache can sometimes cause many strange problems
avillanueva
23-Emerald I
23-Emerald I
October 27, 2023
This appears to align to your problem:
https://www.ptc.com/en/support/article/CS325202?source=search
Perform following steps to 'Reset' workflow roles
  1. Edit the affected workflow template from 'Workflow Template Administration'
  2. Click Properties of workflow and select to Roles tab
  3. Select Reset for all listed roles > Save and Check in the modified workflow template
  4. Again Edit the affected workflow template. Click Properties of workflow and select to Roles tab
  5. *Unselect* Reset for all listed roles > Save and Check in the modified workflow template again
Note : PTC recommends backing up the data before performing any changes
It not works😭
avillanueva
23-Emerald I
23-Emerald I
October 27, 2023
Can you post more of the error message especially when it starts?
Hi @YZ_10818805
Fixed after restart
I don't know why
