Basic Ant and packaging question
MM_13610538
I am using Windchill PDMLink Release 12.1 and Datecode with CPS 12.1.2.7
I was curious how to compile just our custom Java code. I can't seem to find the right ant command.
Should the Java files be put in /codebase/src/... and then I issue an ant command?
If I compile our custom code to a Jar instead of several .class files, does this result in better performance? Where should the .jar file go?
What OS are you on? For a long time, I let me IDE do the compilation against Windchill Jars outside of Windchill but since then I moved toward build scripts at the target host. Are you doing lots of development work or is this a one off? If anything simple, what @Jimwang is best course.  If you are using GIT and need to develop a automated build process, there are some other threads here that can help.
If you could point me to automated build processes, that would be helpful.
