Hi, I have to deliver an entire offline copy of a producton a certain date. I've looking into using Packages but theProduct Structure viewonly contains alimited amount of data. Additionally none of the related objects are linked to the part objects. What is the best way to accomplish this? I am currently running PDMlink 9.1 M060.
Thank you!
Thank you for your replies.
We have looked at the export functionalitybut it does not provide a InteractiveProduct Structure interfacewhere you can navigate through and access all the data. It does not look as though it containsall of the linkage betweenparts and related objects. It only exports documents and associatexml files with limited metadata.
As far as data contained, I need all of the CAD files, and all related object files to be included as a number of parts contain "Described By Documents" and such.The intended use may be to then import it into another PDM system, I'm not sure. I only have the requirement to deliver an complete offline copy.
Thank you again, your comments are very helpful.
Thanks Ryan,
So if you export using that function, how do you view the product structure and linkage toall related objects? (other than Product Structure to Excel)
I havenot checked this particular data export using PLM connector but may be you cantry using it. Note - it has a limitation of exporting only Pro/Engineer CAD Data and IDEAS CAD Data.
