We just trying an upgrade from 10.1 M030 to 10.2M020 on atestenvironnement (with all the process recommanded by ptc : Install new version 10.2, datapump Oracle database, export/import Ldif, Then following the pre and post install and upgrademanager) I had some troubles during the upgrade but all resolved by CS on ptc website. Following this, I have a 10.2M20 OOFT but with our data ( metadata,WTdocument,EPMDoc, Parts or Softypes.. who are in database and it works) After that we apply our customisation (the same we use in 10.1M030) and after a SM restart, All the JSP page are blank. If Only customised JSP page where blank we undestand but here, many standard pages not customised all blank like Clipboard, preference, new problem report or new part. we try the classic ant command likeant -f tools.xml customer_build;ant -f jsfrag_combine.xml;ant -f jar.xml under WT_HOME/bin directory but nothing doing. Is someone has an idea or already has the trouble. Last Thing, We don't have any errors under windchill or tomcat logs...
Yes, We use JavaScript but on standard page, there is Java Scripts and it doesn't work too
We think about it too but in the preference page for example, we didn't touch anything and it didn't work
Did you check your Locale setings? are they en_US ?
Sound like good David. it is effectively Java Script trouble. After a detailed analyse of ours files, we have a size and modified date difference between the Windchill-all.js from 10.2 OOTB and this deployed by our system.
We test with original file and All is good.
Thanks a lot. We are gooing to check what we modified on it .
(Windhill-all.js under/ptc/wt/windchill_standard/codebase/netmarkets/javascript/util)
