Hi all,
I'm creating a 3d drawing in creo and my workspace is in windchill. I save a sketch in my workspace and when I want to used the sketch that I saved to a new 3d model, it doesn't appear in my palette.
Please see the screenshot below.
This is my workspace.
This is the sketch that i want to open in my palette
This is what appear when I used the palette in a new drawing.
Luar
Luar,
use the following config.pro option.
<path>
Specifies the path for the sketcher shape directory that contains the subdirectories that define the tabs and shapes that you define for the sketcher palette.
You can also specify a PDM location as the sketcher shape directory. Ensure that you are in the PDM environment and have adequate access rights to the PDM location.
Martin Hanak
Luar,
<path>
Martin Hanak
