At one point in time I was able to log into Windchill as an admin and also login as a user. Due to some update, I am no longer able to do so. Can anyone point me to the browser setting that will allow this behavior? As I am building a WC 9.1 upgrade environment, it would be so helpful to have both logins.
Thanks, Kathy
Windchill 8.0 M050 Production, MS XP Pro x64 Bit, V2003, SP2
Windchill 9.1 M060 design / test
IE 8.0
David,
It looks like maybe it was the switch from IE 7.0 to 8.0 that created the change. Even if you don't save your password and delete all the history, a second IE 8.0 browser will still not require a login. The lack of a log out in Windchill has always been a fail in my opinion.
I've been playing with this in both my WC 8.0 production on my workstation and the WC 9.1 test on a separate laptop.
The scenario of opening a second browser using In Private does work and may be my best solution. I did take a copy of the discussion Randy Jones suggested and put it in our ‘would be nice folder’ in our Windchill 9.1 implementation stuff. Maybe I will learn to become a backhand Java person. J
Thank you all – you guys rock!
Kathy
