Windchill 11 MO20 - Auto-numbering is turned on...and correctly auto-numbered SolidWorks CAD file attributes are being automatically overwritten in a specific context when saved...the CAD File name is overlaying the CAD Name. is this a Windchill preference somewhere? This is not the behavior we want. Any ideas? Which preferences/settings affect these attributes?
Thank you.
The preference: operation/upload operation/naming parameter appears to be working for what we need. I added a setting in it for SOLIDWORKS and set it to the field Description to match Solidworks 2016.
Upon save to workspace, the CAD NAME field is NOT being overwritten by the number or file name! Same with check-in.
This looks like NAMING PARAMETER setting is the solution? See attached graphics.
Is this how that preference is supposed to work? Thanks!
With the limited information provided, I feel that, there is change in the preference level between site level & context level.
Can you please check below preference in both site & at product level?
Site/Context>Utilities>Preference Management>Operation>New CAD Document>Synchronize CAD File Name with CAD Document Number
If this does not solve your query, request you to provide step by step of the actions carried out to understand the issue.
Pankaj Mooteri
Product Manager, PTC
The problem is the CAD NAME is somehow sync'ing with either the CAD FILE name or the CAD Number.
STEPS TO RECREATE: Using WGM for Solidworks 2016, Windchill 11 - In Solidworks, we do a FILE/NEW - create a new part. The part gets correctly auto-numbered.
Set the Description Parameter which is what we want the CAD NAME to be.
Just doing the function of SAVE in Solidworks to my workspace and the CAD NAME is over-written by (one or the other) File Name or Number.
This is happening in multiple contexts, on multiple machines.
NOTE: The preference "Synchronize CAD File Name with CAD Document Number" is set to YES in the Site, Org and Context levels - that appears to be working.
Could this have something to do with OR be resolved by using this pref? operation/upload operation/naming parameter
Also, there is a USE CURRENT ATTRIBUTE MAPPING option as well..?? I am not familiar with these prefs.
Thank you.
Yes, "Naming Parameter" specifies the CAD tool designated parameter or property attribute from which the CAD document name is copied during initial upload. It is working as expected.
I suggest you to review the section "Policy-Managed Naming and Numbering" under Windchill Help.
Pasting the content below for ready reference, so that it would provide some clarifications on the expected behavior.
Hello All,
My requirement is similar to this.
when user creates a EPM doc from CATIA V5 > file > New,
and when we try to check in this file o Windchill,
Number will be Auto Generated.
Name will be - user provided while creating new CAD document in CATIA
File Name - Here File Name is like < Name>+.ext.
But my requirement for File Name is like,
File Name = <Auto Generated Number >+file ext.
to achieve this which preferences to be set ?
Kindly advise.
Vivek Uchekar
