CAD Worker Timeout
gkemner
7-Bedrock
CAD Worker Timeout
How do I configure the cad worker to shut down or release the license it is using after a certain amount of inactivity? I believe that can be done, I'm just not sure where I go to set that at.
Hi Greg,
you can change this line in the ptc.opt file (you can find it in the Flexnet installation dir).
Time is in seconds
TIMEOUTALL 2700
But if your request is to free Creo license for the use of other users, you can ask your PTC commercial to give you (it's totally free) the dedicated license for cad worker called "PROE_FoundationVis".
Marco
In Reply to Greg Kemner:
Marco
rkobs
2-Explorer
(To:gkemner)
Thanks for the information on the Vis license type, will inquire with PTC.
For management of existing license utilization the following setting is available in the CAD worker configuration wizard:
* AutoIdleStop (sec) - Specify an amount of time in seconds that determines how long the worker can remain idle before it is automatically stopped. If you leave this field empty or set it to zero (0), the worker is not stopped automatically at idle time. Use this option if you need to release the license when it is not being used.
bob
RandyJones
20-Turquoise
(To:gkemner)
In the worker configuration UI there is a field called AutoIdleStop. You can set that field to the number of seconds the worker will set idle before exiting. Or you can simply edit the agent.ini file, change the autoidlestop field as apppropriate for all the worker entries, and then "Reload" from
the "Worker Agent Administration" dialog.
In Windchill 10.2 the agent.ini file is located at:
<windchill_install_dir>/Windchill/conf/wvs/agent.ini
In Windchill 9.1 the agent.ini file is located at:
<windchill_install_dir>/Windchill/codebase/agent.ini
Don't know about 10.0 or 10.1.
Randy Jones
Systems Administrator
Great Plains Mfg., Inc.
1525 E North St
PO Box 5060
Salina, KS USA 67401
email: -
Phone: 785-823-3276
   Fax: 785-667-2695
