CN Affected Objects Table To Set State/Transition Obsolete based on the Disposition Value.
Hi All,
Like every Engineering Change Notice/Order. The from/to table is very close to the affected and resulting table. Some companies like to set state/transition the affected table of objects to obsolete based on disposition and effectivity. Also, there are business rules where you can only put released items in the affect table of an CN. While the new or new revisions of objects get production released and applied also based on effectivity, the affected table of objects can remain released or get set to obsolete/supersede based on the disposition. This is the closed-loop process of a change request to a change notice. The resolution of a change request is both the obsolescence of the affected table and release of the resulting table in the change activity/notice.
This should be out-of-the box functionality. It seems that the functionality is not complete and needs customization to complete the simple very common process.
