Can I force users to add a comment every time they check in files?
Hi Mark,
The two jsps of check in wizard are
Windchill\codebase\netmarkets\jsp\wip\format_content_holder_checkin_step.jsp
and
Windchill\codebase\netmarkets\jsp\wip\non_format_content_holder_checkin_step.jsp
the textarea for putting comment <textarea wrap name="comment" id="comment" cols="53" rows="5"></textarea>
May be using javascript you can force user to make check in comments
Thanks and Regard,
Kaushik
You can use CSS .
class="required "
<textarea wrap name="comment" id="comment" cols="53" rows="5" class="required "></textarea>
Hi there,
I had the same problem.
How to force comments during "Check In" to PTC Windchill (Essentials)?
Solved by some tweaks in javascript.
Unfortunately, this does not work with auto-check-in.
Cheers
Matthias
Is there a way to prevent auto check-in (Creo File Menu action)?
I am afraid there is no way to deactivate auto checkin. Maybe in Creo 4 or 5.
