Hi Guru's
Can we install Windchill 9.1 M060 with SQL Server 2008 ? Any experience with this kind of configuration, tips & tricks ?
Pradeep Shinde
Hi Pradeep
Check the document
http://www.ptc.com/WCMS/files/77024/en/Windchill91M062SoftwareMatrices081111.pdf#page=21
As per this compatibility matrix Windchill 9.1 is compatible with SQL Server 2008
K.Mahanta
In the guide we have a statement ( pg 12, bullet 13 )
Oracle 11.2.0.2 and SQL Server 2008 R2 is supported for all 9.1 releases as of June 2011. See patches for Windchill 9.1 to support Oracle 11gR2 or SQL Server R2 that must be applied. Oracle 11.2.0.2 is supported with the Windchill installation as of M062. SQL Server 2008 R2 is only supported as an upgrade, not as part of the Windchill installation.
I want to install new Windchill 9.1 M060 with SQL server 2008.
Hi Pradeep,
I am facing the same issue right now.
Could you figure out.. what exactly it is meant with:
"SQL Server 2008 R2 is only supported as an upgrade, not as part of the Windchill installation. "
Shashank.
