Can we get rid of Template on Create Change Notice layout?
RG_11025060
9-Granite
Version: Windchill 12.1
Use Case: Can we get rid of Template on Create Change Notice layout? or at least make it read-only and default it to a particular template?
Description:
HelesicPetr
(To:RG_11025060)
Hi @RG_11025060
You can set the default template in the Change Template Administration
also you can disable others templates. Also you can set the templates for each change type.
PetrH
HelesicPetr
(To:RG_11025060)
Hi @RG_11025060
PetrH
Fadel
(To:HelesicPetr)
@HelesicPetr is right then you get :
Fede
