Index Search Module Unable to Install
KG_11714884
9-Granite
I run setup.vbs
Update Existing Installation.
I can not find Search Index Module to Install, see
HelesicPetr
(To:KG_11714884)
Hi @KG_11714884
I am sure that you have to chose the standalone installation, not update existing.
Then you just have to configure the Windchill installation to use the index search.
Installing the Index Search Server in Standalone Mode
PetrH
Hi @KG_11714884 ,
Please post your question in PLM > Windchill > Installation forum for quick response.
This forum is dedicated towards customizations hence you may not get desired response from this forum.
Bhushan
Hi @KG_11714884,
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Vivek N
Community Moderation Team.
HelesicPetr
(To:KG_11714884)
Hi @KG_11714884
PetrH
Hi @HelesicPetr ,
Thanks. I managed to install Index Search Module.
I was doing update existing one.
Since it was already install hence unable to check the box (Client).
To install server need to do new installation and then standalone installation.
