All -
I know this is an older post, but I have a user today who experiencing the same issue. Does anyone know what the resolution was here (if any)?
Thanks in advance -
Chrystal Johnstone
Red Dot Corporation
We have had this issue a couple of times. As a resolution, PTC supplied us with scripts to detect and then fix the problem. They were never able to figure out what the root cause was. They said it usually occurs on migrated data, and after you run the scripts, it shouldn't happen again, however we have had to run the scripts twice so far....
Was there any update of Soft attrubutes done recently to your Windchill Systems ?
Bcos we faced the problem on completion of this activity on the Migrated data.The SQL script from PTC will fix this issue.
In Reply to Jamie Momber:
Hi Jamie,
Could you please upload this Script, I'm facing the same issue?
Thanx
The scripts that PTC send are usually system specific so sending other people scripts provided by PTC could do more harm than good.
I have seen this issue countless times, yes one of the main causes can be once your have migrated from Intralink to PDMLink. The main root of this problem can be to do with null valued attributes within your family table.
What the scripts do is fix any family table members with the erroneous attribute values.
If you're lucky the methodserver may even give you the problem attributes to fix the issue (rarely but I have seen it once or twice)
You will not be able to directly modify the affected model(s) themselves but you can add them to a workspace (from a stand alone web browser session) and then edit the attribute values (if you know this is the issue)
Otherwise PTC send PTC your methodserver log file and they will get R&D to create a script to correct these errors. Be warned I have seen this issue pop up again once PTC fixed the problem, usually when users are editing attributes in the family table and remove values.
Hope this helps you guys out.
-=D
I agree with Dipesh, although I don't believe this script was system specific, I'd rather that you get the script directly from PTC.
