Change Documents - Process Tab
GregOlson
Is there a way to remove the members table from a user's view? For the average user, this is confusing and just clutter.
Yes it's possible. The customizer's guide has a section on it.
From a high level, you need to find which Action Model has that tab and it's command defined on it. (codebase\config\actions\*-actionmodels.xml)
Copy the action model section to the custom-actionModels.xml file
In the custom-actionModels.xml, remove the action that you don't want on that tab.
We recently removed the Relationship Explorer from all the tabs. I found the tabs where it was used, below is the example I found for CAD Docs,
<model name="cadInfoPageTabSet">
<submodel name="infoDetails_cadx"/">
<action name="modelStructureGWT" type="msr"/">
<submodel name="content_cadx"/>
<submodel name="related_cadx"/>
<submodel name="changesTab"/">
<submodel name="history_cadx"/>
<submodel name="requirementTraceabilityTab"/>
</model>
The sysnavTab is the Relationship Explorer, I commented it out. You can restart Windchill, and the actions will be reapplied, or you can go to the site preferences, turn on Client Customizations, then you will get a new icon in the navigator for customizations. Go there, go to Tools and then there is an option to Reload Actions which will not require a restart. I would then recommend to set the preference back to off for Client Customizations.
Hope that gets you pointed in the right direction.
Steve D.
See below, these are the changes that I made....commenting out the members table.
-<model resourcebundle="com.ptc.windchill.enterprise.change2.changeManagementActionsRB" name="changeNoticeProcessTab">
<action name="changeWorkItemsTable" type="changeNotice"/">
<action name="processHistory" type="workflow"/">
<action name="discuss" type="forum"/">
I am a bit confused, do I leave the orginal xml (changemanagement-actionmodels.xml)file alone and copy all of the above
to the custom-actionModels.xml file?
<listofactions/>
Above is our custom table OOTB, what should it look like?
I am a novice when it comes to customizing UI.
Greg
Yes leave the changemanagement-actionmodels.xml file alone.
In the custom file you want to copy from the <model> to </model> tag. Then comment out or delete any items you don't want.
The out of the box custom file has the <listofactions> tag closed since there is no items in it. So you just replace that with an open and a close tag and put the modified models between it as shown below.
<listofactions>
<model name="changeNoticeProcessTab" resourcebundle="com.ptc.windchill.enterprise.change2.changeManagementActionsRB">
<action name="listTeamCC" type="team"/">
</model>
</listofactions>
