Change Management Customization
BenLoosli
Does anyone have a detail, concise document on the steps to customize the change management forms and workflow associated with change request?
Things that we have identified to change are the change request form itself, the workflow process to add a few steps for signoffs and the roles that need populated with user names.
We are running Windchill/PDMLink 10.0 m040 with Creo2 m100.
BenLoosli
(To:BenLoosli)
I did figure most of it out eventually. We have been using Windchill Change Requests since October of last year. Still have some issues and will need to reset the sequence numbering once the last few issues are resolved.
Lots of areas in Windchill that need modified to make it all work and little documentation. Windchill help explains the functionality of what to do for the change but very little on the why or its consequences.
6 REPLIES 6
LoriSood
23-Emerald I
(To:BenLoosli)
What exactly are you looking to customize on the forms and in the workflow? Are you trying to validate information in the wizards?
doehr
(To:LoriSood)
I'm thinking silence is golden, and other posts have covered this.
doehr
(To:BenLoosli)
Found this one as a More Like This link from another discussion, a year old...is this still an issue for you?
I am starting to get asked similar questions about what we can do in this area.   So far I haven't found any good answers, but I have just started looking around.
BenLoosli
(To:BenLoosli)
doehr
(To:BenLoosli)
Welcome to my life . We've had to figure out the "why" and consequences on our own, which is why having a baseline change management policy for your company really, really helps.
