Change Request - Layout Change
rkumar-4
Hi All,
     I have been working on implementing Change management (OOTB). As i progress, i was willing to know, if it is possible to change to ootb layout as per our old format of CR's.
Currently, we are using excel for creating CR's.
The current CR in excel contains data of "what parts are deleted / added / qty modified" in an assembly. See attached screen capture for reference.
Can some one help me out to tell if this is possible to do it in WC OOTB. .If so any guides would be greatly helpful
You can change Windchill layout or you can use query builder to find your data.
In this document Resource for reporting there is a section about Change management.
Hope you can find what are you looking for.
Marco
