Change Request Summary report Description
  • August 2, 2022
  • 2750 views
When we run the Change Request Summary report  (Actions -> View Summary Report), the Description and Proposed Solution fields are blank.  The other fields get reported correctly.
We also get an Error which might not be related:
[ContainerBackgroundProcessor[StandardEngine[Catalina]]] com.ptc.netmarkets.util.misc.DBOperationHttpSessionListener - No active method context
wt.method.server - Dead method context [id= ... ... ]  threadName=Thread-nnn] was never unregistered
This is a Jasper report.
thanks -- Rick
Best answer by SWeiler_9940261
What version of Windchill? This could be because description and proposed solution are RTF as of 11.1. See support case:
https://www.ptc.com/en/support/article/cs298196?language=en&posno=2&q=rich%20text&source=search
rleir17-PeridotAuthor
Hi team:
This failure is consistent on every run of the  Change Request Summary report.
Same on a very lightly loaded WC server.
(I have been told 'This would be a priority issue')
We also get an Error log:
Message: Dead method context [id=nnn, threadName=Thread-nn] was never unregistered
Context Label: /Windchill/netmarkets/jsp/report/jasper/jasperAsyncHeartBeat.jsp
Is that related?
Do we have to configure HeartBeat as described in the following page?
https://community.jaspersoft.com/documentation/jasperreports-server-administration-guide/v550/configuring-heartbeat
I have not mentioned this to our security people yet.
thanks -- Rick
Hot on the trail through:
$ view loadFiles/reports/LoadJasperChangeManagementSummaryReports.xml
$ view codebase/netmarkets/jsp/changeReports/ChangeRequestSummaryReport.jsp
$ view codebase/netmarkets/jsp/changeReports/ChangeItemSummaryReport.jspf
$ view codebase/netmarkets/javascript/change2/changeReports.js
Still trying to get the Description and Proposed fields populated.   Please help
cheers -- Rick
