Change Task Attributes missing during edit
Wayne.Beck.Gen
6-Contributor
I am facing a problem where the attributes on the first step of the edit change task wizard are not displayed.
This is at wcadmin all the way down to a user with technically the correct access.  I have sifted through all the ptc CS and nothing has fixed my issue.  I can update resulting objects and finish the wizard just fine.  This is on a customized system with little documentation.  13.0.2.0
Fadel
23-Emerald I
(To:Wayne.Beck.Gen)
Can you double check the edit layout is set correctly :
Fede
10 REPLIES 10
Fadel
23-Emerald I
(To:Wayne.Beck.Gen)
Any errors in logs when this happens ?
Fede
Wayne.Beck.Gen
6-Contributor
(To:Fadel)
Nothing that sticks out.
Fadel
23-Emerald I
(To:Wayne.Beck.Gen)
Fede
Hi @Wayne.Beck.Gen
Do you use a Profiles? Someone can add you to a profile where attributes can be hidden from the user.
Also check the edit layout settings in the Type and Attribute Management.
PS> if you say customized system what does it mean?
PetrH
They had edited the jsp pages and we dont have any documentation of what was done.
Hi @Wayne.Beck.Gen
That is a very bad situation.
If you do not know how the jsp page has been modified then it is really hard to find root case,
A sharing the jsp pages could help to identify the issue, but I could understand it is not possible
PetrH
Fadel
23-Emerald I
(To:Wayne.Beck.Gen)
get the ootb file from another system to revert back
Fede
HelesicPetr
(To:Fadel)
@Fadel
Good Idea if @Wayne.Beck.Gen can do it.
PetrH
Aside from using GIT or a good source control system, standard procedure would be to copy the PTC original file to the wtSafeArea/ptcOrig folder in a similar path. Did the previous administrator follow that step?
on some things.
