I am using Windchill PDMLink Release 13.0 and Datecode with CPS 13.0.2.3
After Importing the CAD Data in the Windchill, references are missing. For the assembly child objects are not showing and in Whereused tab the objects are not listing.
While Importing the data errors where showed as
2025-04-29 09:31:27,324 INFO [Thread-22] wt.system.out wcadmin - ApplicationImportHandlerForJar: storeLogMessage: USER LOG: <"EPMDocument: tsop-6_arw_crk.prt ( 0033183376 ) 0.0" cannot be imported because the revision "0" is invalid. >
Which was resolved and then data was imported
After this import on source server
On Target Server
On Source server
On Target Server
BR,
Saurabh
Can you try to reimport using option 'Resolve overridable conflicts'
Hi Fadel,
The data has been imported now, but facing the issue mentioned above. I suspect the issue seems while importing. The option mentioned we have tried but not resolved the issue.
BR,
Saurabh
