Version: Windchill 12.1
Use Case: I have created a Reference Document Template using an Excel Document.
Description:
When trying to create the first Reference Document using the new Template I get the attached error. Not sure which field is creating this issue?
Hi @IanW
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry. For example:
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
Hi @IanW
The method server logs could help you to identify the root case.
The error just say. that you put string value in the integer type so it is not compatible
If your excel file contains some columns that are linked to the Windchill attribute, then be sure to use correct excel type column.
PetrH
Petr,
I help Ian with this post.
You would not believe what I found.
The TemplatesUtilitly.changeFilename() method was failing while trying to get the filename truncation length from the preferences.
The line that failed is below.
Integer var14 = (Integer) PreferenceHelper.service.getValue("/com/ptc/windchill/enterprise/templates/doc/filenameTrunctionLength", "WINDCHILL", var13, var12);
The PreferenceHelper.service.getValue() method return an Object which happens to be a String in this case. I did confirm this. And it is deprecated.
So, I hacked the class and changed it to a non-deprecated method to get the object and then create the Integer object.
Object obj = PreferenceHelper.service.getValue(var13.getContainerReference(), "/com/ptc/windchill/enterprise/templates/doc/filenameTrunctionLength", "WINDCHILL", var12);
Integer var14 = Integer.valueOf(obj.toString());
The hack works great.
I have passed this on to TS.
Curious to see what they come back with.
FYI, the PreferenceHelper.service.getValue() method is deprecated. Not surprised by this. I see this all the time with OOTB code.
This was good one. Keep 'em coming 😊
David
So it seems @IanW stumbled on a bug? Any way it can be worked around for now? Is this avoidable?
The OOTB .getValue() method return an Object.
The object is a String.
The developer simply tried to cast the String object to an Integer object. Good luck with that.
I think the easiest, bombproof solution is to do what I did which is hack the OOTB code.
To be honest it was fun figuring out where the code choked and why and then hacking it to get it to work.
As stated earlier, keep ‘em coming 😁
