I have a Windchill system that has been upgraded from 9.1 to 10.1, I now need to move it to another server.
I have installed 10.1 on the target server, cloned the SQL Server database and external vaults, and updated the server name in the relevant tables.
I have imported the entire root LDAP which as two branches 9.1 and 10.1.
I have reimported the configuration branches from the original OOTB install so the server names are correct.
I have also reconfiged the Apache Auth providers to use the 9.1 branch as per the source server.
I think I need to change the search base for the Admnistrative and Enterprise JNDI adapters, but don't know how to do this outside od the Windchill UI.
Any help on this would be appreciated.
Nick.
You can modify adapter using any LDAP editor. Windchill UI ultimately stores all entries in WindchillDS.
Thanks.
I found the info in WindchillDS and was able to update it.
Windchill works, so job done.
