I'm looking for a 3D commercial library already integrated with windchill partlink. I means somthing already made from third part software PTC certified that can by from the market
Hi @Beniamino71,
Could you clarify what you mean by a 3D commercial library?
Are you referring to standard components, or product-specific models?
I refer to standard commercial component as:
Screws
Bearings
electric motors
gearboxes
pneumatic couplings
pneumatic cylinders
Classified for brand end mechanical characteristic
I look for e third-part product certify PTC working on Partslink classification that allow quickly find 3d model to use in Creo Parametrics
B.
There are multiple vendors that provide 3D models compatible with Windchill and Creo.
I am not certain which vendors are officially certified by PTC.
It would be best to check directly with PTC for confirmation.
Ok if you have some vendor reference It will help me to find the best solution for as
B.
@TDT had a good suggestion. Integrating with PartsLink is a tall ask since every one would have this implemented differently. Attribute names, definitions, structure is up to the end customer. There is not one classification for all but likely very similar. Suggested to the Windchill AI Part Classification team that there is opportunity to "suggest" classification based on data they may see from users.
I would suggest that if someone is planning to implement PartsLink, the following URL may be helpful.
https://partsolutions.com/partsolutions/standard-parts-engineering-reuse/
