Working in Windchill 9.1 where there is no softtyping for EPMdocuments. I would like to use a conditional within an OIR to set different numbers for CAD drawings vs CAD Models within the same library. The attribute docType appears to be accepted by the OIR however I do not know what the potential values are for this system (logical?) attribute are. I see that within ProductView it appears the epmdoc_docType can have the value of Drawing. It seems that the system knows about epmdocs as a catagory (search criteria).
Does anyone know of a existing attribute (system not soft) that can be used to determine what an epmdoc catagory is from within an OIR and what that attributes values are?
Kelly Lozier
Dave,
Thanks for the reply. So now that you set the bait out there, yes I am interested in how you were able to softtype epmdocs in 9.1. Is there an issue with doing as you found an then upgrading to 10.1?
Kelly Lozier
BMPC-KAPL
