Dear All
When i try to save and upload or Check in a large assembly. My event manager show failed and invalid response from server.
I have attached screen shots. Please give your valuable comments.
Viswanathan.K
hello
I am facing the same problem on Windchill, did you find a solution to your.
Thank you for your help
The "upload failed because of invalid response from the server" message is fairly generic and can have a number of causes. If the upload failed due to a server side issue, then there should be a corresponding error in the Method Server log that gives a better description of the cause.
Are you seeing this issue with all uploads? Or, does it only occur for certain objects, or for certain users/machines?
Chris is correct in that the error is pretty generic. The MethodServer log should be consulted.
Additionally, there are a few articles that address some situations where this error has occurred:
http://support.ptc.com/appserver/cs/view/solution.jsp?n=CS148175
http://support.ptc.com/appserver/cs/view/solution.jsp?n=CS30885
http://support.ptc.com/appserver/cs/view/solution.jsp?n=CS93882
http://support.ptc.com/appserver/cs/view/solution.jsp?n=CS38354
http://support.ptc.com/appserver/cs/view/solution.jsp?n=CS45185
