How to update parameters in windchill after part checkout & did modification in paramter level inside creo?
  • September 15, 2014
  • 1183 views
Hi
Ex:
I uploaded part inside windchill with paramter (part _name & part_number) which derive from creo.
Then later I am in need to change the part_number & part name for the same part which uploaded previously.
I checkout to creo & did the parameter change and checkin again .I understood that the changed parameter is not updated inside windchill ?
Is there any solution to sort out this issue ???
23-Emerald I
September 18, 2014
Haris,
Are you trying to rename the CAD part or just update the parameter value? If you want to manage Creo parameters within Windchill then you need to set up Windchill IBAs and map them to the parameters. Please refer to the "About Attribute Mapping" topic in the Windchill Help Center:
http://support.ptc.com/cs/help/windchill_hc/wc102_hc/index.jspx?id=TypeMgrAttributeMapAbout&action=show
