Hi All,
Does anyone know how you can create a soft type using a Java expression (to be used in a workflow).
For example to create a Change Notice:
wt.change2.WTChangeOrder2 co = wt.change2.WTChangeOrder2.newWTChangeOrder2();
But how about if I wanted to create a soft type of the Change Notice object called "HT Change Notice"?
Thanks in advance,
Toby
If you'd rather start with the WTTypeDefinition, something like this may work:
public static void main(String[] args) {
try {
String logicalID = "wt.doc.WTDocument";
TypeDefinition typeDefinition = getTypeDefinition(logicalID);
TypeDefinitionReference tdr = getTypeDefinitionReference(typeDefinition);
} catch (Exception e) {
e.printStackTrace();
private static TypeDefinitionReference getTypeDefinitionReference(TypeDefinition td) throws WTException, WTPropertyVetoException {
TypeDefinitionReference tdr = TypeDefinitionReference.newTypeDefinitionReference();
TypeDefinitionForeignKey key = TypeDefinitionForeignKey.newTypeDefinitionForeignKey();
key.setBranchId(td.getBranchIdentifier());
key.setId(PersistenceHelper.getObjectIdentifier(td).getId());
tdr.setKey(key);
return tdr;
private static TypeDefinition getTypeDefinition(String logicalID) {
try {
QuerySpec qs = new QuerySpec(WTTypeDefinition.class);
qs.appendWhere(new SearchCondition(WTTypeDefinition.class,WTTypeDefinition.LOGICAL_IDENTIFIER,SearchCondition.EQUAL,logicalID),new int[]{0});
qs.appendAnd();
qs.appendWhere(new SearchCondition(WTTypeDefinition.class,WTTypeDefinition.LATEST_ITERATION,SearchCondition.IS_TRUE),new int[]{0});
return (TypeDefinition)PersistenceHelper.manager.find((StatementSpec)qs).nextElement();
return null;
You need to get a TypeDefintionReference. There are several ways you can do that.
Let's assume you have the type String type = "wt.doc.WTDocument|com.CustomDocument"
Generally, it's something like this
TypeDefinitionReference tdr = wt.type.TypedUtility.getTypeDefinitionReference(type);
WTDocument doc = WTDocument.newWTDocument();
doc.setName(....)
doc.setNumber(...)
doc.setContainer(...)
doc.set.................
doc.setTypeDefinitionReference(tdr);
doc = (WTDocument)PersistenceHelper.manager.save(doc)
try {
tdr.setKey(key);
return tdr;
try {
qs.appendAnd();
return null;
Can the latter be used in a workflow expression? I have not tried the first post yet, but it is very similar to the expression that I have used to create a Change Notice in a workflow before so I shall try that one first.
Just about any compilable java can be used in a workflow expression (the WfExpression bodies are compiled into java classes). You must use full package names for anything outside of java.lang.
