Ciao,
anyone tried to compare performance or other abilities between embedded Creo browser engines IE and Chromium? It is driven by config parameter "windows_browser_type" and can be set up to "ie_browser" or "chromium_browser".
Running on Creo 4 M060 with Windchill 11.1 M020 but see not much difference between these two options. What should I test/compare to get some meaningfull result? Anyone using IE or Chromium in long term to share experience? Thx in advance
My browser details are here
Know that article but it is general info. I am more curious about real testing/xp/results from daily use...
We tested this as well, I don't really have any performance numbers to share. We had to stop testing the chromium engine because of incompatibility with internal websites and stayed with the IE option.
We're on Creo 4 and WC11.1
Cannot use the Chromium browser as does not show the thumbnail images.
IE embedded browser sometimes has an issue display pages such as promotion request text boxes properly.
We stuck with IE and use F5 to refresh the page when it doesn't appear
No real performance change between the two that we have noticed
