Hello all,
We are running Creo 1.0 M050 w/ Windchill 10.0 M030.
After Creo crashes, I restart the application and it will then hang on the "Retrieval" Window ("Creo Parametric was not closed properly...Click retrieve or continue"). I am pretty sure it has to do with Windchill - in particular two lines in my config file. I know this because if I remove these lines from the config, Creo will not hang on the retrieval window upon startup.
The config file lines in question are:
pro_format_dir wtpub://Windchill/Libraries/Library/Formats
start_model_dir wtpub://Windchill/Libraries/Library/Formats
If I start Creo after a legitimate shutdown (not after a crash), everything loads just fine with no hangs.
Any ideas?
Andri
Some times even after a shutdown you can't get in.
I could resolve it by removing the folder C:\Documents and Settings\%USERNAME%\Application Data\PTC\.ptcm1912
But this cleanups your local workspace
. You will lose your un-uploaded modifications.
Do someone have a better solution?
The ptcm1912 is the browser cache. Not the wgm folder.
You can remove this folder and will not lose any of the unsaved work to server.
I've got a ticket in with PTC on this currently. I'll let you know what they come back with.
This Option worked for me ![]()
last_session_retrieval no
Aziz,
that config option works for me as well. Never used the retrieve much anyway...
Andri
This worked for me.
BTW, here's the response I got from PTC's tech support:
Hello Domingo,
I have been doing some testing on this issue, and it does not seem as though this is possible. However, I am going to talk to some members of R&D to see if they know of any way to do this.
Pathetic!
I've got an open call on this as well. I'm able to repeat the issue so I'm hoping I'll have some success with PTC support.
It looks like PTC has taken this issue seriously. I've got an SPR and they've created a customer service note as well CS164045. The issue hasn't been resolved, but they believe that it is a problem. Step one complete.
Robert,
I looked up this SPR, and in it it says they have no plans to fix. I tried to set the config option, but that did not work for me.
Dennis Rehmer
I have exactly the same problem, can't do anything about it. Tried deleting the folders mentioned by Joao, didnt help. I cant even start Creo because of it.
Milosz,
Are you able to get Creo to start if you rename the workspace cache folder (.wf)? If so, then the cache was probably corrupted too much to be able to recover.
