Custom JavaScript in WIndchill 10
vipindas_karuna
Hi ,
I have defined functions in "custom.js " and i am trying to include the
functions in the "custom .js" into my " customized.jsp" by adding the
following tag in the .jsp
<script type="text/javascript" <br="/>src="netmarkets/javascript/custom.js"></script>
But the jsp doesnt find the js file and its functions.
Although if i define the functions from the ".js" into the ".jsp" directly
, it finds the functions .
I even tried creating the "jsfrags " defined in the Windchill 10
Customization guide , but it didnt work either .
Has someone worked on" JavaScript" in Windchill 10 .
Thanks ,
Vipin .
7 REPLIES 7
Maybe put a "dot slash" in front of netmarkets?
src="./netmarkets/javascript/custom.js"
Patrick Williams | Engineering Systems | o: 616.698.3766 | c: 616.947.2110
[cid:image001.jpg@01CC4B8D.1A083840]
I would suspect the jsp compiler is collapsing the script tag try:
<script type="text/javascript" src="netmarkets/javascript/custom.js"></script>
In Firefox the JSView and Firebug addons let you see what has been loaded. I believe IE 8 and later will do the same thing with their Tools -> Developer Tools.
Craig Raymond
Windchill / Web Developer
BAE Systems
Intelligence & Security
Enterprise Technology Services
600 Main St, Johnson City, NY 13790
hi,
Use PTC.LoadScript("netmarkets/javascript/custom.js");
thnaks
Forgot to CC list...
Have not heard of the PTC.loadscript method suggested will have to try.
Original reply follows...
Sent from my Verizon Wireless BlackBerry
Hi Everyone,
The tag that worked
<script type="text/javascript" <br="/>src="../netmarkets/javascript/custom.js"></script>
i guess it was looking for one level above for the .js .
Special Thanks to David , Morkel ,Raymond and Williams for your help .
Vipin .
I'm wondering what the advantage of using the PTC.LoadScript method is?
Craig Raymond
BAE Systems
hey sorry guys load script is something like this..
language = "text/javascript"
'netmarkets/javascript/test/mytest.js'
IE caches the responses for any js files loaded via PTC.navigation.loadScript() API
