Custom MVC Table Builder is not fitting on GUI Window
SA_9497989
7-Bedrock
I have created a one custom mvc tablebuilder which invokes through jsp page. this table builder displays on single wizard page. this table builder is not fitting into a popup window after displays table there is a lot of empty space.
Hi @SA_9497989
I would advice to show us what is your issue with screenshots and description what is your goal.
PetrH
Hello HelesicPetr,
PREVIEW
Thanks for your reply.
Please follow the below steps to reproduce issue.
1) create single wizard step
2) create custom mvc table builder and try to display table builder on single wizard step then observe the custom mvc table is not fitting with GUI Window I mean there is a lot of empty space. Please observe the above attached screen shot. Please let me know how can I solve this empty space issue.
Sudhakar
Hi @SA_9497989
What space are you pointing? the last table column  space? or the underneath space between table and OK button?
From my point of view this is Ok.
PetrH
I am pointing between table and Ok button.
@SA_9497989
It is common behavior.  In the table there are just two objects.
Show more rows in the table and check the result.
btw what is your goal? Space issue does not say what you want to see/do. Do you need to set window size to smaller window?
Or resize just the table?
PetrH
