Is there any way we can add new attributes in the Customizing Table Views, when I try to create a new custom view I can see the some attributes are missing is there any way we can add it
Hi
You should be able to add your own IBA's to views.. Wondering why you are not able to see them in the list of available attributes.
BTW, from where are you launching this custom View UI ???
~Mahesh
Hi Mahesh,
Here is the steps I am following.
step 1: Search for the WTPart
step 2: In Search table select custom view
Step 3: Add attribute here (some attribute are not there )
In you search criteria make sure you have just the part type selected. Then it will display the default part view and you can customize that view to add your attributes. For the users you can create saved searches and expose it
Thank you
Binesh Kumar
Hi
This is strange... Hope you just selected WTPart and not ANY OTHER TYPE and all your attributes are mapped to WTPart level..
I remember the issue if you select more than ONE type then Windchill Search UI does not give option to add custom attributes.
~Mahesh Gupta
did you validate that your attribute is filterable?
